Fan control module campaign
Old Feb 2, 2021 | 09:15 PM
  #31
David Ellison's Avatar
Originally Posted by babyhuey
If you have a 2003-2006 Mazda 6 with the 3.0 V6 engine, there is a current campaign out labeled SSP 71 that calls for inspect and usually replacement of the fan control module. Modules have been failing very often due to internal assembly soldering problems. These problems can cause the cooling fans to run all the time, not at all, or have erratic fan speeds. Dealer will inspect and'or replace the fan control module free of charge to you under this campain.
If you would like for me to check and see if this or any other campaign applies to you or if it will just be a wasted trip for inspection then send mea PM with the last 8 digits of your VIN. I will probably only be able to check North American market vehicles.
Hello, I just experienced this about 6 weeks ago the fan started working only sporadically, blew up my car 2003 Mazda 6 w/ 3.0 6 cylinder engine, I want to fix it but so far have found it's very expensive, then I remember this Mazda forum, when I got on here this is the first thing I saw, and it's what happened to me, if anybody give me any clues or point me in a direction for getting an engine for my car without costing an arm and leg contact me at ... davidellison5691@gmail.com, thank you
Old Feb 11, 2026 | 07:50 AM
  #32
Blairware's Avatar
Originally Posted by sloppyface
i hear that variable speed happening when the car is in park and run for about 5 sec. after car is shut off. my question is what happens if this is let go and not fixed?
Your vehicle explodes in a spectacular fireball of light and heat. Why do you ask, 17 years ago, via time portal?
mwoods4843
Aug 21, 2025 09:43 AM
gsxr98
Jun 12, 2025 06:07 PM
dc20187
Jul 27, 2022 04:03 PM
santy
Dec 28, 2009 01:40 PM
6GuyInAZ
May 18, 2006 02:05 PM
