Cold weather issue
Hello all. I'm dealing with an unusual problem with my '19 Mazda 6 touring. The windows freeze shut all the time. Up here in MA we've had a lot of rain one day then frigid cold right after. All the windows freeze and won't come down. It makes going to the drive thru for morning coffee a challenge.(our local Dunkin is only drive thru due to covid so going inside isn't an option) anyone else ever had this problem?? I have to go out in the morning and pour warm water around the frame of the window... sometimes it works sometimes it just freezes also. Any ideas would be appreciated. Thank you!
On my third Mazda, currently. (Miata, Mazda3, and CX-5.) The CX-5 hasn't developed slow-moving or "stiff" electric window syndrome, yet, but it's still early days. Wouldn't surprise me if it did.
But here are a couple of write-ups about things to check.
1. Stiff or Slow Window Fix @ wiki.miata.net. Removal of the door's panel and then cleaning and re-greasing the tracks.
2. Regreasing Slow Miata Windows @ did-it-myself.com. Removal of the door's panel and then cleaning and re-greasing the tracks.
3. In my own experience with these Mazdas, it's often the case that the window seal surround above and around the window gets a bit sticky. Best solution I've found for that is: using 303 Aerospace Protectant on a regular basis, to keep the rubber clean and pliable, which seems to eliminate this particular variation of the culprit.
I'm a little surprised that you're seeing it on a 3yr old vehicle. But by the fifth year, I've had slow windows on two of three Mazdas. So, you never know. But, in all cases cleaning and re-greasing the tracks drastically improved the speed of window function, to the point of seeming like-new. Unless there's something going wrong with the electronics, I'll bet those two things (clean/re-grease, and the 303 application on a regular basis) solve it.
Interesting the product you use while it seems not to have petroleum or alcohol ingredients, which is a good thing on any rubber, plastic and many other no mantellic composition materials it does have H2o. Last time I checked water freezes!
I think I will give it a try. I like most things that are similar that won't deteriorate my vehicles.
Of course, there's the old stand-by for some folks: a decent silicone spray. Like NAPA's Mac's, or Blaster silicone, or DuPont silicone. I find that the 303 helps keep the seals and weather stripping in peak condition, though a good silicone product might be better with the water repellency/-proofing.
