Anyone have the wiring Code for 07 Mazda 6
Old Aug 11, 2008 | 12:52 PM
potty's Avatar
Default Anyone have the wiring Code for 07 Mazda 6
I was wondering if anyone can give me the correct wire codes for the RR+, RR-, LR+, LR- and the switched wire.
I'm trying to put an amp in the trunk of a 07 Mazda 6 Sport. I've been to three different websites and have gotten three different wire codes. None of them are correct. I really don't want to spend $35 to get this info so I'm hoping someone can help.
A correct reply would be greatly appreciated. Thanks.
Old Aug 11, 2008 | 04:15 PM
potty's Avatar
Default RE: Anyone have the wiring Code for 07 Mazda 6
I finally got the correct wire codes. I'll post them later along with some pictures of an amp install. This car is a piece of cake after you get it tore apart! Later.
Old Aug 13, 2008 | 11:11 PM
potty's Avatar
I just finished putting a MTX 12" Sledgehammer in the trunk of my 6. Piece of cake! It's almost like they built this car with the aftermark stereo install in mind.
I took the battery out of the car and down behind it there's a plastic plug. I drilled the hole thru that and I was in the car! piece of cake!
I also mounted the bass boost **** in the console by the lighter with a mini toggle to turn the amp on and off. I don't like using my subs in the winter and this is easier then pulling the sub amp fuse.
Here are the true color codes for a 07 Mazda 6 Sport. I find 3 different ones on line and none of them where correct. These are.
RR+ Blk/Blue
RR- Wht/Blue
LR+ Pink
LR- Purple
Remote turn on lead I used the switched wire on the cigerette lighter.
I'll post some pics when I get a chance to snap some tomorrow.
Old Aug 15, 2008 | 12:24 PM
potty's Avatar
Here's a couple of pics of the install. Like I stated before, it's a piece of cake after you get the factory stereo out of the dash.
I removed the bass boost **** from the case and mounted it in the dash. Looks good but the blue led is very bright at night.
Old Aug 16, 2008 | 10:05 PM
potty's Avatar
Trouble with the upload the first time.
NelsonGTX
Mar 4, 2012 12:33 PM
stasha
Nov 2, 2008 01:43 PM
ro2go
Aug 1, 2008 12:35 PM
racer10
Oct 29, 2006 01:51 AM
