2011 Mazda 6 - loss of power
Old Jun 22, 2013 | 01:22 PM
douginamherst's Avatar
Default 2011 Mazda 6 - loss of power
I have a 2011 Mazda 6 with 76,000 miles. OK car but nice to drive on interstate. In the last month, the power is definitely lower than previously. I changed the plugs at 30000 and 60000 miles with Iridium plugs and all was good until about 72000, then it dropped off. I have to nearly floor the accelerator to get it to downshift and then move.
The check engine light was on for 2 weeks and then went off. Code scanner shows no codes. Gas mileage is about normal, 27 to 29 mpg.
Any suggestions?
DOug
Old Jul 1, 2013 | 11:06 PM
go-part's Avatar
Former Sponsor
Old Jul 2, 2013 | 09:16 AM
I would do easy standard stuff first:
Clean MAF sensor, clean throttle body, and change the PCV valve (as Mazda never did).
While you are doing this re-set the ecu by disconnecting the battery.
READ: https://www.mazdaforum.com/forum/gen...setting-31827/
Re-start car and let idle for 10-15 minutes. re-learning has begun for next 50-100 miles. After this put in fuel system cleaner.
zildjian71
Aug 22, 2013 10:04 AM
mx6racer
May 14, 2010 06:44 AM
DreadPir8
May 1, 2010 03:42 PM
joshy28
Jul 14, 2007 12:36 PM
codylo
Jun 21, 2007 11:40 PM
