2007 Mazda 6 - Unable to Dip Hi/Low Beam
Old Aug 21, 2020 | 03:04 AM
Twisted_Engineer's Avatar
Unhappy 2007 Mazda 6 - Unable to Dip Hi/Low Beam
Noob 1st post here, please be gentle.
Hi,
Not-so-proud owner of a 2007 Mazda 6 2.0L Diesel Hatch. Suspect I have caused this by adding LED globes to the HI beam only, possibly at a higher current draw then the original halogens.
Symptoms: Headlights will turn on and off correctly when combination switch is twisted.
Headlights will NOT switch between HI and LO when the combination switch is pushed forward / pulled backwards. Headlights stuck on HI beam. Pulling back on the lever when the lights are off correctly brings up temporary hi beam.
I can't find a dimmer relay anywhere, only a general headlight relay (70A) which seems to be working correctly (on/off). Am I correct in assuming the only option left is to pull and test the combination switch on the steering column?
Many thanks for the help....
Old Aug 21, 2020 | 03:24 AM
SOLVED
Issue above solved. Found a short inside the headlight assembly itself. A direct result of me and my fat fingers.
Not the result I would have expected, given the symptoms.
Now to get back to adding some driving lights.
kenp005
Apr 25, 2022 12:11 AM
blue12
Nov 4, 2021 03:28 PM
daviddarville
Feb 9, 2009 12:40 PM
trs
Jun 27, 2007 03:31 PM
quinto555
Jan 12, 2006 10:44 PM
