2006 Mazda 6 starting problem - clicks
Old Apr 8, 2014 | 12:25 PM
cmalone's Avatar
Question 2006 Mazda 6 starting problem - clicks
This occurs sporadically but it's been happening more often in the last few months. I turn the key and it just clicks. Repeat anywhere from 1-20 times and it eventually starts. Battery is new. Lights/accessories power is fine. There's no problem cranking so I'm ruling out starter/solenoid. Suspected a ground problem so I cleaned battery terminals & cables. I've read in a couple of posts about the ground connection to the body (other end of the negative cable) corroding. I haven't checked that. Sound familiar? Suggestions?
Also, unrelated to the starting issue, I've noticed that often after I shut down, there's a buzz/hum coming from under the hood that lasts 1-3 minutes and then stops. Anyone have any idea what that might be?
Thanks In Advance!
CAM
Old Apr 8, 2014 | 01:24 PM
Don't know about clicking, but i can help you with some ground issues for this model as mine is the same, pics are mine!
Extra ground wires from negative terminal of battery to body, engine block and tranny are good ideas. Tranny if automatic, mine is 6 speed aisin warner crap tranny (make sure you install external tranny cooler on this).
The stupid ground is located in front of driver side wheel, under air filter, in front of fuse box.
Old Apr 8, 2014 | 03:27 PM
cmalone's Avatar
Thanks, Noggin. I like how you put your avatar on the last pic.
Old Apr 10, 2014 | 07:40 AM
Dont rule out the starter.
jackrabbitpunch
Aug 11, 2011 10:42 AM
1989Quest
Feb 1, 2011 01:32 PM
Xaisho
Nov 23, 2010 06:12 PM
herl
Sep 12, 2010 08:10 AM
jloncp
Sep 24, 2007 04:45 PM
