2004 Mazda 6 Fog Lights
Old Oct 12, 2013 | 08:48 PM
acreu61's Avatar
Default 2004 Mazda 6 Fog Lights
My '04 did no have fog lights, I bought some aftermarket ones but it seems the car does not have any wiring set up for it? can someone tell me if I can get the juice from the side markers so that when the city lights are on the fog lights can come on as well? or do I need to run new hardness from the fuse box and a new switch from the dash ?
Old Oct 13, 2013 | 03:04 AM
Depends on the local traffic laws where you live.
Old Oct 13, 2013 | 09:04 AM
Depends on what kind of fog lights and the power draw. LED would be a good alternative in your case that doesn't use much power, otherwise separate circuit please.
Old Oct 13, 2013 | 11:35 AM
acreu61's Avatar
Thanks guys, looks like the hard way it is, damm! any best tips on how to deal through the firewall without too much damage?noise later... it seems the current wiring takes all the room on the main through-hole.
Old Oct 13, 2013 | 12:25 PM
Drill a new hole! Rubber Grommet, silicone works.
Removing the battery may make things easier (it did for me on my 2006).
Old Oct 14, 2013 | 05:29 AM
Have a look at the big multiplug for each of the headlights. Some models had foglamps inside the headlight assembly. There maybe wiring there to tap into.
Old Oct 16, 2013 | 06:15 PM
jessyr's Avatar
fog light draws more power and also it is depend on your city light , my suggestion would be try for LED lights it consume less power and also its give different look than fog lights cheers!!
also you can check more information on race car alignment tools.
DJROCKDAHOUZ
May 7, 2014 06:00 PM
Montebello
Dec 30, 2009 09:42 AM
GreekTrouble
Dec 30, 2008 08:10 PM
little_cee
Jan 26, 2008 06:47 PM
karlt10
Apr 11, 2007 09:18 PM
