08 Mazda6 2.3-only 53k miles-mildly rough idle?
Old Sep 28, 2019 | 01:33 PM
Flybye's Avatar
Default 08 Mazda6 2.3-only 53k miles-mildly rough idle?
Hi all. Is the 2.3 supposed to be a little buzzy? No CELs, and it drives perfectly fine. Only thing I am wondering about is a mildly rough idle. It is not severe, but you can feel it through the steering wheel.
I am going to replace the air filter, but I figured Id ask before cleaning out the TB and MAF sensor.
Old Sep 28, 2019 | 10:58 PM
Have you checked your engine mounts? A worn engine mount can translate engine vibration thru to the chassis.
Old Sep 28, 2019 | 11:06 PM
Flybye's Avatar
I thought about it, but with only 53k miles? I did have a 2009 3 with 160k miles with shot motor mounts that made the car sound like it had an exhaust leak.
Old Sep 28, 2019 | 11:10 PM
The car is over 10yrs old, well & truly could be degraded & worn out by now.
Old Sep 30, 2019 | 11:26 AM
bulwnkl's Avatar
Agree; check motor mounts. If that, and air filter, and other simple checks or replacements don’t do it, you could check valve clearance (aka lash). The 2.3 MZR in our ‘06 Mazda 5 had manually-adjusted valves, so I assume that’s the case in yours. Probably not the issue, but a thing to check.
Old Sep 30, 2019 | 05:06 PM
Flybye's Avatar
Ok will do. TY. I guess the general consensus is these 2.3s should be smooth enough to not feel anything through the steering wheel.
2006Tribute
Jun 9, 2020 03:15 PM
sillysandwich
Jul 20, 2019 08:28 AM
NursemyMazda
Nov 20, 2012 03:37 PM
rnunez1989
Mar 29, 2011 02:32 AM
626tex_mom
Nov 9, 2008 06:50 AM
