07 mazda6 headlight have to hit to come on
Recently the left headlight wasnt coming on, I hit the outside of it, came right on, then one time it was both hit them came on, last time right headlight didnt come on, hit it came on. Im not convinced its the bulbs, any have this issue and how do you fix it?
Any update to your problem? Did you find a solution? I ask because my girlfriends mazda 6 is having the same problem. We thought it was a bulb problem and replaced them with no results. I gave the headlight a bump and that did the trick. Noticed as she was leaving the house this morning that it was off again.
No, I don't believe so. I've never dealt with HID headlights but when I changed the bulb the other day it seemed like a normal high beam bulb. Sylvania H1 bulb I believe. After changing the high beam bulb both lights (high and low driver side) require the "bump" to get them working. I've checked the connections on the new bulb and everything seems okay. No corrosion or cracks in the wires.
1993mazdaMX6
Mar 31, 2007 11:41 PM
