07 mazda6 headlight have to hit to come on
Recently the left headlight wasnt coming on, I hit the outside of it, came right on, then one time it was both hit them came on, last time right headlight didnt come on, hit it came on. Im not convinced its the bulbs, any have this issue and how do you fix it?
loose connection
i dont think it is, bc i wiggled the wires after it came on, didnt turn it off. Ive seen a lot of people having this issue anyone figure out the solution?
Fit some new bulbs.
I don't think its the bulb, those HD def lights either work or don't.
Any update to your problem? Did you find a solution? I ask because my girlfriends mazda 6 is having the same problem. We thought it was a bulb problem and replaced them with no results. I gave the headlight a bump and that did the trick. Noticed as she was leaving the house this morning that it was off again.
Do you have HID headlights?
Common problem is the ballasts (transformer / igniter unit) play up and slowly die. |
had this issue on an old 6 of mine (2007) diesel.
Was 'hitting' the body work adjacent to the light unit to make it come on - lasted about 6 months and ended up changing the bulb (passenger front). |
(Post 140208)
