04 6 rear pads
Old Aug 11, 2005 | 02:48 AM
rabirza69's Avatar
Default 04 6 rear pads
Hey all... replacing the pads on the 6 today and i ran into a problem with the rears.. I could not get the piston to compress to get the caliper to fit over the new pads on the rears. the fronts were a breeze, used a c clamp with an old pad and boom it went right in... I actually broke my clamp trying to compress the rears, any suggestions.. someone told me that the rear piston had to be twisted in rather than pushed .. is this true?
Old Aug 11, 2005 | 12:52 PM
gtxtreme's Avatar
Default RE: 04 6 rear pads
That right, the piston needs to be turned clockwise, Mazda list a special tool. There're aftermarket adjustable types available.
The two hotches on the piston is where the tool fits. Have to leave the hotches @ 12 & 6 oclock so pins on pads will lock into
the piston. Every time the hand brake is used, the piston is adjusted out if needed.
Old Aug 11, 2005 | 01:24 PM
Patrick's Avatar
Administrator
the tool is usually pretty cheap, and should come with several different surface plates, for different cars..i know that tiburons and mustangs are the same way in the rear.
Old Aug 12, 2005 | 03:20 AM
babyhuey's Avatar
Hopefully you used a very cheap c-clamp as the e-brake mechanism for the rear caliper can be damaged as well as caliper operation if the piston is compressed too hard the wrong way. Make sure all is working correctly after pads are installed or you might have a big suprise next time you set parking brake on a hill!!!
Old Aug 15, 2005 | 03:40 PM
Patrick's Avatar
Administrator
once you have them screwed in, youll want to pull the ebrake a few times to make sure that it works...
Old Aug 16, 2005 | 12:08 PM
Fragile's Avatar
have you had any luck with it yet, where did you get the tool?
49er
Jun 17, 2015 04:13 PM
Torque
Jan 20, 2015 09:01 AM
grenman
May 29, 2009 11:21 AM
Richard
Oct 11, 2007 10:48 PM
miguerh
Aug 13, 2006 11:05 PM
