size of front sway bar bushings?
Old Nov 27, 2012 | 02:42 PM
livewire78640's Avatar
Default size of front sway bar bushings?
Need help, I have a 2009 Mazda 5 and need to replace front sway bar bushings. I need to find out what size are they, like 23mm, 20 mm etc. Want to order some better aftermarket ones like Energy suspension. Or Energy suspension part number etc.
Thanks
Old Nov 27, 2012 | 05:39 PM
tanprotege's Avatar
Your best bet is using calipers to measure the sway bar diameter.
Old Feb 19, 2013 | 02:17 PM
slbenz's Avatar
This maybe a little late to reply but the fronts are 23mm and the rears are 20mm in size. I replaced both the front and rears during the President's holiday with Energy Suspension bushings. You will need to drill out the openings of the brackets that Energy Suspension provides in order for the factory bolts to fit properly. This goes for both the front and rear sway bar brackets. Use the originals as a template.
deadwood
Dec 17, 2011 04:06 PM
CapitalismGoneWild.com
Apr 24, 2009 08:30 PM
braxus
Mar 20, 2009 11:07 PM
Estlander
Jul 11, 2006 03:26 PM
morris95626
Jun 13, 2006 10:50 PM
