Obd2
Old Nov 14, 2018 | 08:21 PM
jan's Avatar
jan
Default Obd2
Hi,
I have a 2007 Mazda5, 5 speed. Trying to figure out the codes for "check engine" light. Innova customer service have told me my Innova scanner is not compatible with Mazda. ??????? it is a 2007???? Also noticed that on the emissions decal under the hood, there is no mention of the car being OBD2 certified. The NAPA shop people told me that my car should be OBD2 certified???? it is not. When I hooked up my scanner, yes, there is a plug, in the usual mazda place, I get the V.I.N. and 1 DTC. but nothing else.
The car still runs. I am guessing that is is an oxygen sensor or a fuel ratio sensor. So how do I go about figuring out the problem, finding a solution?
Old Nov 15, 2018 | 05:09 AM
Time to find another scan tool.
Old Nov 18, 2018 | 12:40 AM
Ruling out a problem with the diagnostic connector in your car.....Your scanner should work on your car. Try to use your scanner on another car.
But as another member said you may need to warranty it or get a new one.
Old Nov 18, 2018 | 07:53 PM
jan's Avatar
jan
Thank-You
I am looking at an Autel.
Does Mazda use only generic codes or do they have some of their own codes as well?
The lower cost scanners only recognize generic codes.
Old Jan 7, 2019 | 09:39 AM
cennric's Avatar
Thank-You
Which Autel model you bought? I am also thinking to buy an Autel scanner. I am not finding cheap scanner from this brand! I just saw this autel scanner list https://obd2scanners.org/autel/ and most of these scanners price isn't affordable. It looks like Autel create scanner only for professionals. Find only one scan tool which price less than 100 bucks.
Old Jan 8, 2019 | 02:39 AM
Originally Posted by jan
Thank-You
Mazda uses a wider range of codes than alot of cheap scanners will read/recognize. And also the description by some scanners of codes read & associated circuits can be a bit confusing or misleading.
Damin69
Aug 16, 2011 11:49 AM
stumpy1505
Nov 7, 2010 02:00 PM
hajjat
Jul 26, 2010 02:40 PM
Athon08
Oct 11, 2007 10:57 PM
