Coolant in the ignition coil housing HELP MAZDA 5
Old Sep 4, 2022 | 11:39 AM
Caami0123's Avatar
Default Coolant in the ignition coil housing HELP MAZDA 5
Hi guys I have a Mazda 5 2010 and I found engine coolant in the ignition coil housing, the coolant is not in the combustion chamber. Somehow I'm thinking the coolant is leaking through the intake manifold or exhaust gasket and making its way through the engine head and getting into the spark plug/ignition coil housing (Cylinder 1). Anyone can confirm this theory for me please?
I did a coolant pressure test. It's not holding pressure but no visible leaks were found.
Thank you!
Old Oct 14, 2022 | 02:07 PM
Colasandy's Avatar
I’m pretty sure as engine is Ford based there are coolant core plugs between 1-2 and 3-4 plugs. On fords these leak very common but only seen it on the smaller engines. Pull out the coils and have a look at an angle down plug holes to try find out. If it is these it’s cam cover off and get them replaced. Not a huge job
masonswork
Aug 10, 2022 06:25 PM
rtaylor
Mar 22, 2021 08:44 AM
rlb
Jun 24, 2014 02:16 PM
bozanbo87
Nov 5, 2009 05:43 PM
mazda guy
Nov 12, 2005 03:33 AM
