code reader not reading
Old Mar 3, 2024 | 08:57 PM
steve050554's Avatar
Default code reader not reading
Can any body explain why my Foxwell code reader (and multiple bluetooth ones ) wont connect to the ecu/pcm via the obd port ???
Old Mar 4, 2024 | 09:48 AM
If it is a blue tooth IMHO based on countless customers using them often have connect ability issues with OBDII and CANbus diagnostic connectors. Either get a replacement or get a REAL* Diagnostic scanner the plugs directly into the OBDII diagnostic connector.
I would suggest that you also seek someone that has one *^^^ that can confirm that you do not have a failing ECU.
Old Mar 4, 2024 | 10:40 AM
I have a Foxwell 604 (I think) that I bought because the bluetooth cheapo ones wouldn't work. It has the plug in lead to the unit and other end to obd port.Initially it gave a couple of problems with the dpf being sooted up, and also said 'may have an internal pcm fault' . Now it just wont connect ! If it is the pcm that is failing, could I just get one from a breakers and would it work or would it need recoding by Mazda ?? It is a 2008 2.0 diesel manual.
Old Mar 4, 2024 | 12:32 PM
As I suggested have you OBDII diagnostic connector checked with w hopefully professional shop quality Diagnostic scanner the connects directly to the OBDII diagnostic connector.
ASE
Taz 454
Jun 22, 2021 06:23 AM
xericx
Mar 4, 2012 04:13 PM
berjara
Jan 31, 2009 06:27 PM
LS1Steve
Nov 9, 2008 11:50 AM
coodem
Sep 20, 2007 03:58 AM
