Brake pads knocking on 2007 Mazda 5 2.0d Sport
Old May 13, 2019 | 06:03 AM
Joseph Masih's Avatar
Default Brake pads knocking on 2007 Mazda 5 2.0d Sport
Knocking sound following replacement of rear brake pads and discs. Fitments are correct to best of knowledge. Fitted correctly and securely as confirmed by experienced ATS Euromaster technician.
Any thoughts as to cause and remedy please?
Many thanks.
Dracarys!
Old Jun 29, 2019 | 09:03 PM
Dens5's Avatar
I had the same issue. It turned out to be corrosion (aluminum oxidation) in the caliper where the guide pins go. The effect was that the caliper compressed and retracted unevenly, leaving a gap that allowed the pads to knock. I removed the pins, used a screwdriver to scrape out the build-up, lubricated everything and reassembled. The knocking went away. Hope this helps.
Old May 21, 2020 | 07:27 PM
icspots's Avatar
Old thread, but the rear calipers on many Mazda’s you have to compress and turn the piston to retract it for pad replacement because of the parking brake. Once you’ve finished the job you have to pump the parking brake until it firms up. That ratchets the piston back into the correct default position.
MazdaTirol
Oct 3, 2012 03:53 PM
warrior86
Jul 21, 2011 11:44 AM
cy131
Apr 5, 2010 08:09 AM
leopold2
Jun 13, 2007 03:20 PM
craigmack
May 2, 2006 07:01 PM
