Audio system question
Old Jul 8, 2020 | 11:51 AM
TedR's Avatar
Default Audio system question
My 2009 Mazda 5 has had a wonky aftermarket audio system for as long as I have owned it. The audio system quit working the other day so I removed the unit and replaced it with a used factory unit with one cd changer and no nav. The wiring was a bit of a mess. The large connector had previously been removed and subsequently re-connected, although it doesn't look completely correct. The small connector was missing. So I plugged in the large connector and the radio and cd work as expected. The steering wheel controls also work fine.
So here's the problem: Everything works as expected except the aux in. I plugged an MP3 player into the aux in but it is not recognized. I suspect the missing small connector might be the problem, but I don't see any unconnected wires in the audio compartment.
Any suggestions would be much appreciated.
Ted
Old Jul 16, 2020 | 05:02 PM
Slh25421's Avatar
Default Possible interior fuse out for auxiliary connection
Hi, I am working on trying to get my auxiliary connection working also. I have determined that the interior fuse is out. It is located on the interior of the passenger side door.
Ted
Possible Fuse our for Auxiliary connection
Farmer
May 29, 2019 06:45 AM
Madeofsteel85
Apr 20, 2018 01:11 PM
steimy
Mar 28, 2010 06:52 PM
Schwarzwald
Oct 4, 2009 05:08 AM
