2009 Mazda 5 Front/Rear Shock Replacement
Old 12-01-2018, 12:07 PM
tannercortes's Avatar
Default 2009 Mazda 5 Front/Rear Shock Replacement
Hi
2009 MZ5 has blown driver side strut. I want to replace both fronts and also the rears. I am going to replace the sway bar bushings if I can find a kit.
I would like to make it easier by purchasing a quality complete strut assembly but questioning if that's not a recommended move since the spring may be inferior to the OEM one.
looking for recommendations.
thanks
Old 12-12-2018, 01:11 PM
shawnmos's Avatar
I think I went with a complete strut set from Sensen (usually found on ebay). They were cheap but work well enough. Also check out RockAuto. They have sets from monroe or moog that are probably better. If you want to keep your spring it's a bit more work but you can rent a spring compressor from most auto parts stores for free. If you decide to replace all of the mounts and bump stops and such it ends up just being cheaper to get a compete set.
Indiemsc
06-19-2018 11:37 AM
wrightmartin
11-03-2014 08:16 AM
fflt765
05-24-2012 05:19 PM
bmaez
05-12-2011 06:38 PM
purebeach77
05-09-2011 08:54 PM
Quick Reply: 2009 Mazda 5 Front/Rear Shock Replacement
