vvt sprocket
Old Mar 20, 2019 | 05:47 PM
Pat66's Avatar
Default vvt sprocket
hello everyone..having an issue with the vvt sprocket.should it be locked or unlocked when installing it into the camshaft and doing the timing?
Old Mar 21, 2019 | 06:17 AM
1st up the crankshaft & camshafts need to be locked before removing the chain. The cam sprockets are timed to the camshaft via a locator pin.
Hope this helps.
Old Mar 21, 2019 | 07:01 AM
Pat66's Avatar
Default VVT sprocket
Thank you for the reply.all that has been done.everythung is set on tdc.cams are aligned in the back with a flat stock .set screw to stop the crank from moving is in.but the vvt sprocket is not in lock position and therefore when i remove the flat bar from the cams the intake cam moves several tooth marks because of the valves pressure.not sure if thats how it should be or not.
Old Mar 21, 2019 | 07:05 AM
Pat66's Avatar
I forgot to mention that this model does not have set pins on the shaft for the sprockets.have to install friction washers and super tighten them to prevent from moving.sucks i know but thats how they made them.
Old Mar 25, 2019 | 08:14 AM
Pat66's Avatar
Is there anyone who can help me with this issue?
Old Mar 26, 2019 | 07:50 AM
What year, model & engine do you have? I can have a look in the workshop manual for you.
Old Mar 26, 2019 | 03:24 PM
Pat66's Avatar
Its a 2007 mazda 3 2.3l gas engine .not turbo....thank you.
Old Mar 26, 2019 | 03:29 PM
Pat66's Avatar
I got info on the vvt sprocket.should be locked.but i assembled everything to spec.and turned the engine several times manually to make sure all was set.and it looked good to go .but when u cranked it.it knocked right away and when i removed the head the 2 exhaust valve broke like toothpick inside the fourth piston.niw i have to redo it again.what can this issue be?
Old Mar 27, 2019 | 04:58 AM
According to the workshop manual, you need to mark the position of the VVT sprocket to the camshaft before disassembly.
Also, you need to lock the crankshaft & camshafts in the cylinder head using a special service tool, before touching any part of the timing chain system.
Old Mar 28, 2019 | 03:19 PM
RGAZ's Avatar
It sounds like he has the flat bar on the cams and the pin in the crank, so he is using the special tools. What it sounds like is that after install the cams move as the VVT actuator moves all the way clockwise (or counterclockwise
). Could there be a requirement to have the actuator all the way one way when installing?
I am curious as I will be doing this repair soon on my 06 2.3L and the manual is not clear.
RGAZ
stonej420
Sep 2, 2016 02:00 PM
opus291
May 6, 2012 11:23 PM
dm2smooth
Oct 27, 2007 01:44 PM
maddy1407
May 10, 2007 05:18 AM
