91 626 cam sprocket align pin breaking off
Old May 6, 2012 | 11:04 PM
opus291's Avatar
Talking 91 626 cam sprocket align pin breaking off
I replaced a head gasket on a 91 626 (had head checked and shaved at machine shop) I replaced the timing belt and since then shortly after starting I have had 1 cam sprocket bolt and 2 alignment pins break. The engine seems to turn without problem so if anyone has any input I would greatly appreciate it
Old May 6, 2012 | 11:23 PM
MazdaTirol's Avatar
Check your camshaft bearing bores and camshaft journals for wear and seizing up of the camshaft, see if you can turn it by hand, if not you might need a new head, machine shop might have not cleaned out the oil passages to the camshaft and its not getting any oil either. https://www.mazdaforum.com/forum/maz...t-issue-28517/ Also on an edit since the forums seem to be screwed up on my end the new posts are at the top of the pages instead of the bottom............kinda backwards IMO.
And welcome to the forums!! Please if you can put your cars info into your signature, you can look at mine as an example, helps us all from asking what you have every time.
Patrick Chin
Feb 7, 2024 08:08 AM
Patrick Chin
Aug 16, 2021 11:30 PM
stonej420
Sep 2, 2016 02:00 PM
BamaSkater09
Aug 14, 2014 06:38 PM
MarioMaverick
Jan 20, 2007 07:46 PM
