options ??
Old Oct 16, 2012 | 10:12 PM
Joe Huang's Avatar
Default options ??
i just got the 2012 mazda 3 hatchback , what would be the best intake to put on ?
Old Oct 16, 2012 | 11:22 PM
MazdaTirol's Avatar
Stock, absolutely STOCK. CAIs, pods, MAFs, they all do diddly on a stock engine, at best you keep some horses at worst you lose some and may even violate some laws depending on where you live. A stock airbox will outperform almost every aftermarket intake when the filter is clean as it should be.
Old Oct 17, 2012 | 08:02 AM
Lightbulb Shades of Shipo
A CAI is prone to water intake from driving thru puddles and car washes. A deflector shield must be installed in front of the tires. You must be sure there will be enough air flow as well, by checking air route from front of car, you may have to drill some holes by fog lights. Getting at colder air is better. In the winter time this must be removed.
SRI: short is good however you will be sucking in hot air from behind the rad as the rad fans will push this hot air in to your intake. This hotter air than stock will cause loss of power until your revs are hi. For this to work properly you must isolate the air from the hot rad air by making baffles all the way up to the hood, a water deflector is also good. You must be sure there will be enough air flow as well, by checking air route from front of car, you may have to drill some holes by fog lights. Getting at colder air is better. This can be kept over winter by putting extra air filter scren over it that comes with it, or bought for it.
I did this on my Mazda 6 and it works great! The pic shown is before i had to put water deflector as you can see openings under filter ahead of tires.
icspots
Aug 25, 2007 10:11 PM
s_pisco7084
Oct 4, 2006 12:59 PM
2blue
Mar 30, 2006 05:18 PM
Spaz218
Mar 1, 2006 04:48 PM
gijoe24jp
Jul 21, 2005 04:29 AM
