Oil Pump Pickup Tube (strainer) Install - 2004 Mazda 3 S
Old Jun 20, 2019 | 09:27 AM
cewhite3's Avatar
Default Oil Pump Pickup Tube (strainer) Install - 2004 Mazda 3 S
I am having trouble installing the oil pump pickup Tube on the oil pump of my 2004 Mazda 3 S. I have the original gasket and a new gasket. They are not true O-rings. The cross section is taller than the width at the CL. The pickup tube has a shallow recess that I assume is for the gasket to fit in, but the gaskets I have don't fit the recess particularly well (including the original I removes with the tube). Is there a method for insuring the gasket is properly located? I tried to stick it in place with grease while I tighten the bolts, but I am not confident it stayed put. The tube is flat against the oil pump and nothing is hanging out, but I don't want there to be any leaks. Any clues on what I should be doing are appreciated.
cewhite3
Jun 19, 2019 06:08 PM
mtnrotary
Jun 5, 2019 03:34 AM
Tinytim
Feb 21, 2017 08:00 PM
mayberry56
Aug 19, 2009 07:33 AM
Thelonius
Nov 27, 2008 05:21 PM
