Newbie Question
Old May 30, 2010 | 07:29 PM
Siber Express's Avatar
All I can say is thank god for air tools, I had the camber links and the springs changed in about an 2 hours.
Also with extensions and a swivel it is possible to use a ratchet.
Old May 31, 2010 | 12:01 AM
timk125's Avatar
Originally Posted by virgin1
You need to lower the rear suspension between 1-2" (6 bolts) and also loosen part of the fuel system under there. I forget exactly what but these pieces do not need to be removed, just displaced for clearance.
Probably another dumb question, but here it goes. (I apologize for my stupidity)
So does that mean the current suspension is adjustable, or I have to buy after market shocks and springs?
Old May 31, 2010 | 12:21 PM
Tracker's Avatar
Current suspension is NOT adjustable, the only thing you can adjust is the rear toe and front camber and caster and those are very minor and shouldnt be touched period.
Old May 31, 2010 | 01:09 PM
Virgin1 actually should have said to lower the rear Sub-Frame assembly.
It is easier than it sounds.
Old May 31, 2010 | 05:15 PM
Yes! Ken is correct. I should have used the term sub-frame instead. That would have been more accurate. My apologies.
Old May 31, 2010 | 09:42 PM
timk125's Avatar
Alrighty. That makes a little more sense.
Thanks a lot guys. Very very useful information.
k2worldwweapon
Jun 19, 2008 12:06 PM
lyndonri
Jan 9, 2008 04:08 PM
Nebolskeetskeet
Nov 18, 2007 07:38 PM
wreckx7
Oct 10, 2007 02:28 PM
mazdaB2200excab1
Sep 15, 2005 03:19 PM
