Mud Flaps
What ho one and all,
Intending to fit front and rear mud flaps which I will cut myself from some 2mm (perhaps 3mm if the 2 is no good) rubber sheet.
All the bought ones seem to have metal bracket and clips into which the attachment screws are fitted. Given the front has those pop-out trim clips, is there any reason that longer versions of those same pop-out can not be used?
At the rear, since the attachment points appear to be in the flange of the plastic lower bumper, guess it is OK to screw into that?
Thanks
Thanks
