Mazda 3 hedlight adjustment mechanism does not work
Does anybody happen to have any tip for fixing mazda 3 headlight adjustment mechanism? The left light of my mazda 3 is currently aimed too high and because of that it won't pass the inspection. The aiming just doesn't change by turning the screws. I heard that a whole new mechanism would cost ~400€, so if somebody has alternative suggestion to fix this, I would appreciate it. Thanks!
I had a similar problem with my wife's Ford Contour (same as Mondeo). There was a jack nut which had a stripped thread. I got a headlight from the junk yard.
The Mazda 3 headlight seems a bit different:
depending on the model year:
It seems the screw driver itself works as a cog. If that is the case make sure you have the proper kind and size of screw driver.
I hope this helps.
I hope this helps.
STUFFF
Apr 8, 2025 05:47 AM
gsxrsrad1000
May 2, 2007 11:37 PM
