Mazda 3 Engine oil light causing loss of acceleration
Old Sep 29, 2023 | 08:07 AM
Dholvey's Avatar
Default Mazda 3 Engine oil light causing loss of acceleration
Hi , I’ve got a 16 plate mazda 3 sport sky active 2.2l diesel.
A while ago my engine oil light appeared and it’s caused a loss in power when I’m driving . It continues to drive but hardly accelerates.
when I turn the engine off and back on the alarm clears and the car goes back to normal , I’ve found that if I turn my car off then back on straight away the light will appear again causing the same problem within a few minutes however if I leave the car off for a day or two I can then go a week without it appearing.
I changed the oil sensor in the tank and this seemed to of cured it for a while but the problem has come back. Also probably worth noting this problem happened a few weeks after an oil and filter change. Any help would be appreciated
Old Oct 5, 2023 | 05:14 AM
Have you scanned it for fault codes?
Have you had the oil pressure tested/measured?
srk1
Nov 24, 2024 11:21 PM
baj2005
Apr 8, 2024 05:08 AM
Chilligallagher
Mar 1, 2023 09:02 AM
2005Tribute
Jan 3, 2016 12:20 PM
leesol
Oct 2, 2007 06:22 PM
