Key Fob not working
Key Fob not working
So over the past couple of days my fob has not been working. When I go to unlock the car with keyless entry on the door nothing happens. So I pull out the fob and try to unlock it that way but again nothing will happen. I’ll then pull out the key itself and unlock the doors manually and I can get in fine but the car won’t start, it doesn’t recognize the key I assume. The alarm will start to go off after that but I have no way to turn it off as the car won’t start and the fob won’t work. It’ll go off for a few minutes and then the key will just start to work again like nothing happened.
Would this be a low battery issue in my fob, I tried both fobs this morning and the same thing happened with both. So do I need to change the battery on my fobs. Or re pair the keys itself, or reprogram anything?
thank you!
thank you!
It'll help if you add your car model and year, yes it could be the battery CR2025, FOB is nothing more than a encrypted RFID with an amplifier. The receiver coil antenna is integrated with the push button start so if you push with upper part of FOB engine should start even if battery is depleted. They're dozens of videos in Youtube how to replace battery.
thank you!
thank you!
Cas007
03-08-2020 06:33 PM
