Issues with Active Driving Display (Alignment?)
Hi all,
I don't know if this issue had been raised. I noticed an issue with my Active Driving Display, the alignment seems messed up. I can't see the speed properly with my normal driving position, I tried adjusting the height (lowest and maximum on the settings with no success) - I can barely see it if I do the maximum setting and adjust my seat to an upright position, but this was never the case before.
I tried resetting the setting as well as the whole console.
Is there a fix to this? as I do not know how this issue came about. Is it even an alignment issue?
I have a the 2014 with the plastic flip. It was definitely working before but for some reason there appears to be a problem with the alignment.
I do not have a dash mat
Thank you for the suggestion.
Update:
Disconnecting the battery seemed to have resolved the problem.
Thank you so much mate. Have a good day
I just put a dash mat and it was ok the first day. Problem started the second day and the HUD display went to the bottom(-2) and even I adjusted to the highest height, it’s still stays very low, I can’t see the numbers properly. So dash cover mat affected the HUD display position? Wondering was the combiner screen pop up too much? Or the dash mat cover affected the display?
Hi there, I have the same issue but the flap doesn’t sit flush. Any recommendations to fix this?
