idle screw location
Old Sep 9, 2010 | 04:04 PM
fettus's Avatar
Default idle screw location
hi guys dumb question here, can you guys tell me where the heck is the screw to adjust air intake in a mazda 3 2005....my car has 180000 miles and when in idle rps go low to 500 and car tries to shut down...i will replace the fuel filter but dont know where the adjustment of the throttle is.
thanks
Old Sep 9, 2010 | 05:22 PM
shipo's Avatar
While I don't know this for sure, I'd bet that there ain't no such a critter on the Mazda3. Why? Because in this day and age of computer controlled fuel injection systems, idle set screws are more than a bit extinct.
Old Sep 10, 2010 | 03:57 AM
fettus's Avatar
i thought about that...any other suggestions about this issue? check engine is off, i dont know if i can get a code this way.
Old Sep 10, 2010 | 09:39 AM
icspots's Avatar
Did it give a CEL before? Have you changed the intake or are you still on the OEM? Is it only when you're sitting still, or does it cough/run rough when first starting/stoping/turning?
You may want to try cleaning off the MAF sensor, and or see if you can cause it to happen by moving the MAF harness around while the car idles.
Old Sep 10, 2010 | 07:50 PM
fettus's Avatar
yes it gave a cell before too bad i did not checked it i just disconnected the battery...im hoping it lits up again. and it coughs only at ease...it runs great just when i stop it tries to go off. no other changes...btw it has a manual transmission.
Old Sep 11, 2010 | 08:48 PM
Aubrey's Avatar
180000 miles on a 2005?! Holy smokes you put a lot of miles on a car. When was the last time you had a tune up?
Old Sep 12, 2010 | 08:37 AM
fettus's Avatar
yeah i know, tune up? never, im going to change my sparks plugs now to see if it works!!any other suggestion is welcome.
Old Sep 12, 2010 | 01:59 PM
Tracker's Avatar
change your air filter, and oil w/filter while ur at it
Old Sep 14, 2010 | 03:50 PM
fettus's Avatar
Smile
ok guys, the remedy for my car symptom was fixed by a new set of sparks thanks everyone for all your help....
Old Aug 18, 2018 | 11:14 PM
Woodzien's Avatar
Default Idle correction issue
I see this is an old post, but for any future reference.
If you ever change your battery or even disconnect it on a Mazda 3 2005-2008 appx. you want to correct the PCM Memory. The way to do this on this car is simple, there’s no real need to even clean the throttle body.
Run the car in park for 20 minutes with all components,accessories off, AC or anything.
After 20 munites leave the car running and turn your AC on high for 15 minutes then take it on a drive, you’ll be very happy you did this simple and cheap fix. This resets the memory on the Computer and your car should run like new! If you get a CEL don’t disconnect the battery, take it to an auto shop and have them check the codes.
This fixes idle problems though. I’ve done it personally on a Mazda 3 with 130k and it runs perfect like when it was first bought. Hopefully this helps someone in the future despite this post being old.
beachbum
Nov 15, 2009 02:48 AM
tributessuck
Apr 18, 2007 10:05 AM
momindanville
Feb 17, 2007 10:58 PM
samsfanny
Oct 10, 2005 11:26 PM
beachbum
Sep 7, 2005 01:27 AM
