How to Program Remote Keyless FOB on 2004 Mazda 3
Old Jun 8, 2007 | 09:31 PM
bfleck's Avatar
Default How to Program Remote Keyless FOB on 2004 Mazda 3
Can any one provide me with instructions on how to program an extra remote keyless entry FOB on a 2004 Mazda 3s? I can't find the instructions anywhere. I've routinely done this procedure for other cars like my Mazda Tribute.
Old Jun 8, 2007 | 09:50 PM
bfleck's Avatar
Default RE: How to Program Remote Keyless FOB on 2004 Mazda 3
Never mind. Found this in another thread. It worked just great.
I found this on the Mazda6 forum and it works for the Mazda3:
http://forum.mazda6club.com/index.ph...mp;#entry55368
Yes, this does work and I actually used it to program a 3rd remote for my Mazda3i (with power door locks). 8)
*NOTE*
Have all the remotes that you are going to be using, maximum of 3, with you when you do this programming as all of them have to be reprogrammed into memory.
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Sticky this please...
NOTE: Sticky it is. Should it be here or in another section, like the one where you learn how to program a key? Dinu
Old Jun 1, 2008 | 06:22 PM
ROYAL's Avatar
Hi
Jast bought 2004 mazda3 2.3 hachback and keyless dosn't work.
Tryed as above and after step 5) no respond,BUT when i remove key from ignition the car
locks and unlocks 2 times.
any advice.
and forgive my english.
Thanks.
Old Jun 2, 2008 | 06:38 AM
bfleck's Avatar
The timing is important. You need to complete step 4 within 10 seconds. Might also check the battery on the FOB. That's all I can think of. I know I have had good success with this on my 2004 Mazda 3 several times.
Old Nov 11, 2013 | 05:00 AM
autoexpert's Avatar
Lightbulb Keyless programming
2004 Mazda Mazda 3 Key Fob Programming Instructions...
2004 Mazda 3
Close all doors, open drivers door, key out of ignition.
Lock and Unlock the drivers door using the power lock switch on door panel.
Turn key to the ON and OFF position 3 times in 10 seconds. Leave key in ignition.
Close and open drivers door 3 times ending with door in the open position.
Door locks should respond by locking and unlocking.
Press any button on remote 2 times. Doors should then lock and unlock.
If programming a second remote press any button on it 2 times and door locks should lock and unlock.
Remove key from ignition and locks should lock and unlock again.
Test Remotes
Source : Keyless entry key programming instructions - ProgramKeyFob.com
Old Nov 16, 2014 | 03:46 PM
acreu61's Avatar
Default 2004 Mazda 6 key fob programming
So I have tried the several, slightly different, versions on his and still won't work. I though it could be the fob pad it self so I bought a new and nothing. Step #7 doesn't happen. However I do have a couple of clarifying questions: step 2 locks and unlocks ALL doors not just the driver door? also, after step 3 only the driver door locks and unlocks, the other 3 doors stayed locked? Last, do I press 'any' button or does it have to be the' unlock' button... working 2 fobs now. I also disconnected the battery for 5 min as another thread on this topic suggested, nothing still... any other thoughts??????
Old Nov 16, 2014 | 04:25 PM
acreu61's Avatar
In my last post it should say "also, after step 6 only the driver door locks and unlocks, the other 3 doors stayed locked? both fobs have new batteries in them
Old Nov 22, 2014 | 06:21 PM
Bstew7890's Avatar
I'm looking at doing this with my 96 Protégé. I don't have a 2nd key fob but that's not my main concern. The lock/unlock switch that's supposed to be on the door panel is missing. Just an empty hole in the panel. It sounds like this will make it impossible to do the copying process, no?
Bruce D Carter
Oct 28, 2019 06:36 PM
tributeGPK
Feb 9, 2012 01:04 PM
scbhomenet
Mar 3, 2011 09:37 AM
rrue
Jun 2, 2007 06:35 PM
Jmoore284
Nov 15, 2004 10:07 PM
