Fuel in the solenoid valve line
Old Dec 20, 2018 | 05:46 PM
renejuan's Avatar
Default Fuel in the solenoid valve line
Today I was going to replace the purge solenoid valve in my Mazda 3 2006. I was having problems starting up the car every time after refilling gas. I in a post that the likely culprit was the solenoid valve and that it was an easy fix. First I disconnected the line on the front side of the car without issue. Then I disconnected the line on the other side (closer to the cabin) and noticed a little bit of gas came up. Not much but enough to wet my fingers (a few mL). Is this normal? I though this line will only carry gases and non liquid fuel. About 2 weeks ago the car started running with higher RPMs when shifting gears. It goes to 2000 rpms and if I hold the clutch it will go back to normal after 2-3 secs. Should I still switch the purge solenoid valve?
Old Dec 21, 2018 | 08:31 PM
renejuan's Avatar
OK this is embarrassing!! I pulled the wrong line. Whatever was the other line is probably the one that brings gas to the engine. I guess the lesson is do not try to do this late at night with very little light!
dsurls
Jul 17, 2017 12:33 PM
jwh1215
Oct 16, 2010 09:08 AM
JS
Jan 26, 2009 05:19 PM
ansonone
Apr 15, 2008 03:27 AM
MazdaSilva
Nov 17, 2007 09:57 PM
