Fuel Pump
Old Feb 15, 2024 | 03:32 PM
Brian Mitchell's Avatar
Default Fuel Pump
Hello everyone. Was hoping to get some insight as to why my fuel pump suddenly stopped working. I thought the old one was bad, so I bought a new one and installed it, but it's not activating when turning the ignition on. Any information would be appreciated.
Old Feb 15, 2024 | 05:15 PM
Well it helps when you give a little more information about your Mazda??
The year, transmission ,engine size and mileage to start!
Then why did you replace a part that you had not first verified it to be the problem? That often more times be DIY causes more additional problems than the one that started the random replacing of parts.
Did you check in the ECU for any pending DTCs?
Old Feb 15, 2024 | 05:18 PM
LOL of wait I just checked your posting history and see this is not the first problem relating to the fuel inductive system.
Old Feb 17, 2024 | 05:30 AM
mimosa21's Avatar
Default Fuel pump
May sound silly but make sure you are not out of gas
Old Feb 17, 2024 | 09:15 AM
Well it is sorta of "silly! here why. If you read he already changed the fuel pump once.
In a FI engine ever change a fuel pump that was not gas wet? ......
And we will "assume" he primed the fuel system before attempting to start with the new fuel pump which would also need fuel in the tank.
Nz mazda guy
Feb 16, 2017 04:29 AM
rajj2012
Oct 31, 2011 08:08 AM
OffDaWallNuts
Jan 14, 2011 12:15 PM
ged010
Jul 3, 2010 04:54 AM
guitar73
Feb 14, 2007 03:32 PM
