Engine Valve Cover
Old Jul 29, 2025 | 09:19 PM
  #21
M314's Avatar
Am I on a journey down the Rabbit hole
Made inquires to Mazda spares on a quote for a Tappet Cover or Engine Cover . Not 1 in Australia
Next 1 arriving end of August .. The Price for this Beauty is $AU700 mmm
Im looking at a alternative to this and would like options for a Aluminum Cover instead
Even if I have to buy from the states or anywhere else on this Globe
Options please
Thanks
Old Jul 29, 2025 | 11:48 PM
  #22
The reason Mazda and many other automakers went with plastic valve cover better heat stable
Aluminum is not always a better choice
A crack in the plastic is hard to find btw.
Old Jul 30, 2025 | 04:46 PM
  #23
M314's Avatar
Perhaps but $700 for plastic is a bit rich
and I thought the aluminum would be a good choice
So is there another substitute
so the problem if damaged would be around the gasket on the inside ?
Thankyou Callisto
Old Jul 31, 2025 | 12:04 AM
  #24
Thankyou Callisto
700 is stupidly ridiculous…
Thier are auto recyclers that may have one very inexpensive?
As I said cracks in the thermal plastic are not always easy to see
but repairable .
And I would still look more carefully at the sensor/valve for damage .
Old Jul 31, 2025 | 12:58 AM
  #25
Charlescrown's Avatar
I'd take the advice of cleaning it then a short drive. The solenoid may be leacking in the seam at the top. They are subjected to engine oil pressure where the seal and cover is only oil splash and I have never seen a plastic cover crack and if Mazda don't have one in stock says something to me.
Old Jul 31, 2025 | 08:42 AM
  #26
They do crack and they do wear from the heat over time. But I do admit the biggest issue with some early Mazda plastic valve covers was warping and constantly leaking where the warp occurred even with proper gasket and torquing.
Old Aug 13, 2025 | 10:28 PM
  #27
M314's Avatar
I have ordered a cover from the States . It was cheaper than the Mazda price
also the oil control valve is expensive so Im pinning my options
on the cover and seeing if this will be the fix
Romanov
Oct 2, 2024 01:32 PM
Anarchy99
Oct 28, 2023 07:37 PM
crackerjakx
Nov 3, 2007 09:28 AM
mankaw
Oct 27, 2007 10:20 PM
keninn
Sep 3, 2005 01:17 AM
