Engine light
Old May 24, 2018 | 05:17 AM
Africa1's Avatar
Default Engine light
Hi guys, was driving to work tis morning and my check engine light came on, i plugged the scanner in and it came up with a fault code saying that the vehicle was over fuelling, but when i did an emissions test the air fuel ratio at the exhaust came out at 14.7 : 1 which is bang on what its meant to be, i ran a couple tests and got the readings below
Old May 24, 2018 | 06:46 AM
What was the actual fault code?
Old May 24, 2018 | 08:50 AM
Africa1's Avatar
Already cleared the code, will run the car abit and if it pops up again will post the code, the blurb that came with the code literally just said its over fuelling
Old May 31, 2018 | 12:37 PM
Africa1's Avatar
Default Fault code
hi guys the fault code came up again, its reading “P0172”
Old Jun 1, 2018 | 04:06 AM
POSSIBLE CAUSE
Misfire
• Erratic signal to PCM
― APP sensor signal malfunction
― ECT sensor signal malfunction
― MAF sensor signal malfunction
― TP sensor signal malfunction
― VSS signal malfunction
• A/F sensor heater malfunction
• A/F sensor malfunction
― Looseness A/F sensor
― A/F sensor deterioration
• MAF sensor malfunction
• Fuel supply system malfunction or improper fuel line pressure
― Pressure regulator malfunction
― Fuel pump unit malfunction
― Fuel leakage on fuel line from fuel delivery pipe and fuel pump
― Fuel filter clogged or restricted
― Fuel return hose clogged
• Improper connection of purge control system
• Improper operation of EGR valve system
• Improper operation of variable tumble solenoid valve
• Improper operation of PCV valve
• PCM malfunction
Zilch
Feb 26, 2015 08:31 AM
MattPanther
Dec 3, 2013 03:50 AM
schlompie
Mar 6, 2012 02:49 PM
Razdude
Oct 31, 2007 04:37 AM
