Creaking Noise
Old Aug 26, 2007 | 03:13 PM
SPeeDy3's Avatar
Default Creaking Noise
When i let off the cluthc and a gas a little i hear a small creaking noise from down under. i cant figure out whether its coming from the back or the front. i usually hear it when im gassin a little in first or second, or when i'm braking from any gear. Could it be those loose bolts that the speed3's have? and where are those bolts located?
Old Aug 27, 2007 | 11:46 AM
LordChrisofSith's Avatar
Default RE: Creaking Noise
I think there is a thread on the rear strut mounts.
You should search for that.
Old Aug 28, 2007 | 08:46 AM
SPeeDy3's Avatar
I went to the dealership and finally got my cold air intake installed. i also got the problem checked out. it was my rear engine mount. gotta go back in two weeks since they dont have the part in. is it better just to get an upgraded moutn instead of getting the one from mazda?
Old Aug 31, 2007 | 08:18 AM
buckeyepost's Avatar
I bought the Corksport rear motor mount inserts and I noticed them squeak once they get hotb/c they are made of polyurathane. They were only $35 vs $200+ for the replacement motor mounts themselves and I've noticed a huge difference in wheel hop reduction and improved acceleration so I'll put up with a little squeak.
Old Aug 31, 2007 | 10:01 AM
SPeeDy3's Avatar
well for the time being mazda will just install the newer OEM mount. later on mayb i'll change the whole mount, but i didn't know that just changing the inserts was an option? was it easy to install?
Old Aug 31, 2007 | 02:37 PM
ORIGINAL: SPeeDy3
Are they replacing your motor mount or motor mount bolt? They just replaced the bolt on mine for the recall. As for the inserts, you don't change them b/c they're arent any stock ones. All they do is fill in the gap and provide a more direct feel. My Mazda dealer installed mine for $40.I love them other than the fact that they squeak a little. Anyone have any ideas on how to stop the squeaking? Some kind of lube? There is no sound until they heat up and then it can get annoying in a parking garage in a 2 month old car, ya know?
Motor mount inserts >>>> http://www.corksport.com/store/item/...nt_Insert.html
What happens if you don't get you recall done >>>> http://www.cardomain.com/ride/2679025/3
Old Aug 31, 2007 | 05:37 PM
SPeeDy3's Avatar
damnnn.. lol.. i cant have that happening. well i called the guys back at mazda and they said its the number 4 bolt on the rear engine mount. my mistake, i thought the whole mount was being replaced. i'm probably goin to replace the whole mount altogether since wheel hop is still there. later down the line...
leanish
Feb 1, 2011 05:54 AM
PaulDoyle
May 8, 2010 03:24 PM
harling01
Aug 30, 2007 07:25 AM
kulen
Feb 24, 2007 02:09 AM
Lupae3s
Apr 2, 2006 03:11 AM
