Radiator cold spots
Old Jul 27, 2019 | 11:46 AM
Flash2204's Avatar
Default Radiator cold spots
Today decided to flush out the cooling system with wynns colant flush as it is overheating. No difference. There is cold spots on the radiator
Hot on the outsides and cold in the middle.
I've had the thermostat changed. Pressure tested and it's fine both pipes are getting hot top and bottom, so the the thermostat is opening as it should be and the cooling fan works fine and the heater works fine. I have to put the heater on to cool it down, not good this time of year.
Clogged radiator?
Time for a new one?
I've noticed the cooling system doesn't take as much
Coolant as it should
Any advice would be appreciated
Old Jul 28, 2019 | 05:28 AM
Radiator needs to be professionally flushed by a radiator shop.
Old Jul 28, 2019 | 09:49 AM
Flash2204's Avatar
Default Radiator
Just ordered a new radiator for it. Its a lot less hassle
Itrii
Aug 14, 2015 11:11 AM
MazdaAEM
Apr 14, 2010 10:32 PM
dentinger
Detailing
Apr 21, 2007 11:11 PM
WarDogsOfNam
Mar 8, 2007 04:18 PM
