Labour time on replacing steering rack
Old Jan 27, 2025 | 11:38 AM
NewbieGad's Avatar
Default Labour time on replacing steering rack
Hello,
my car is a Mazda 2 sport 2008. I think my steering rack might be on its way out?! Slight knocking noise when moving the steering wheel left and right when stationary. Can’t hear anything when going along.
i will double check other components first, but what is the estimated labour time to replace a rack on this car as I know many cars are different, some needing to drop gear boxes and stuff! If it’s a mad amount it could be goodbye for the car!
many thanks
Old Jan 28, 2025 | 06:17 AM
Is your chassis DE or DY?
Common issue is the steering column lower section.
Old Jan 28, 2025 | 06:26 AM
NewbieGad's Avatar
Hi Grimreaper,
It is DE I believe.
Ah, interesting, I’m guessing that’s a more straight forward fix if it is not the whole rack itself?
Old Jan 28, 2025 | 06:34 AM
There is a Bulletin fix where you remove this lower section, slide the two halves apart, clean the splines, lube it with extremely expensive orange grease & reassemble.
Old Jan 28, 2025 | 06:41 AM
NewbieGad's Avatar
Thanks! I will have a look at that.
regarding if it needed to be replaced, what is the name of the part? I’m seeing a lot of names floating around on Google pointing to the same part. I tried having a look on autodoc, but not sure I’m using the correct name for the part
Old Jan 28, 2025 | 06:51 AM
Intermediate shaft.
Old Feb 3, 2025 | 07:19 AM
NewbieGad's Avatar
Intermediate shaft.
Hi Grimreaper,
Do you know the torque specs for the lower pinch bolt by any chance? Had a google but struggling to find anything!
Many thanks
fightingraven520
Sep 29, 2021 01:12 AM
mazda615
Mar 15, 2014 09:23 AM
TomK
Oct 10, 2010 07:42 PM
mazdaboy52
Jul 26, 2009 04:03 AM
83rx7nutcase
Jan 14, 2006 01:14 PM
