GPS issue in 2017 Yaris ia
Old Jan 10, 2020 | 08:11 PM
spearw's Avatar
Default GPS issue in 2017 Yaris ia
This Yaris is a Mazda 2 with a Toyota name on it. The I bought the sd card to gain access to the nav but the gps doesn’t recognize my current location and recognizes 0 satellites. Can I fix this?
Old Jan 11, 2020 | 02:44 AM
Does the Yaris run Mazda's MZD Connect screen & system?
What brand SD card did you buy? New or 2nd hand?
Old Jan 11, 2020 | 06:13 AM
mazdaCPA's Avatar
I have a 16 iA and it works fine. It did go wacky for a while, the location was off from our actual location by 500 feet or so. Toyota wanted to replace the whole system to fix. I reset it to factory settings and it has been perfect for the past 6 months. I would try a reset next.
other questions to consider:
Does the traffic screen show your location? (In the far left top menu)
Did the compass that was there before you put in the SD card work?
Does the SD card turn on the navigation? What location does it show? Does it move at all?
Old Jan 11, 2020 | 08:57 AM
spearw's Avatar
The system is the same as Mazda’s, only with Toyota’s name on it. The sd card is new, bought through Amazon. The maps are there but it shows me in Texas, and it doesn’t register any movement.
Old Jan 11, 2020 | 09:02 AM
spearw's Avatar
Default And...
The compass: I’m not sure if it worked but I was not shown in traffic. I tried the reset to factory settings with no change. I read some people suggest disconnecting the battery to solve the problem.
Old Jan 11, 2020 | 12:21 PM
spearw's Avatar
Default And no compass
The compass does not work either. Suggestions?
the compass does not work either. Any suggestions?
Old Jan 11, 2020 | 12:36 PM
spearw's Avatar
Default Success
I disconnected the battery for a minute, reconnected it, started the car. After I loaded the sd card, it worked!
Old Jan 11, 2020 | 12:38 PM
mazdaCPA's Avatar
Congratulations.
I am amazed how often on the Mazda forum the repair is free or close to it where on the BMW forum, the repairs are $1,000 to $2,000.
bobup
Mar 4, 2022 05:00 PM
steve045666
Jan 9, 2019 08:24 AM
FlyingPi
Dec 19, 2018 01:54 PM
