Wheel bolt pattern Tribute 2008 and earlier models
Would like to know if the earlier model years of the Tribute have the same Wheel bolt pattern as the current 2008 model. I would like to put together a set of rims & snow tires using rims from earlier production years.
Here is my concern, the 2008 Tribute 16" wheel has a 7" wide rim, with a 45 mm offset and a bolt pattern of 5 x 4.53 or 5 x 115 mm.
The 2001 thru 2004 has a pattern of 5 x 4.50 or 5 x 114 mm similar to the tirerack statement. Just wanted to make sure that there isn't a fit issue with the small difference in bolt pattern measurements.
Follow up on this topic, I did purchase used rims from a 2002 Tribute and mounted new studded snow tires. This wheel and tire package is currently in use on my 2008 Tribute and working very well in the recent ice storm and winter weather of north central Indiana.
Black Limited
Oct 12, 2012 12:18 AM
