Washer hoses
Old May 24, 2020 | 01:27 PM
cncman40's Avatar
Default Washer hoses
Just picked up an 04 or 03 tribute with the 3.0L V6 motor.....Someone replaced the hood and did not hook up the washer hose...I know it works as I can see fluid coming out from inside the passenger side fender...When looking at the bottom of the washer bottle which washer pump goes to the front???
Old May 24, 2020 | 05:00 PM
wtriemst's Avatar
Default Washer hose
It will be the lowest pump in washer bottle. More important that front washer to keep working so they put it lower in washer bottle than the rear pump.
Old May 26, 2020 | 12:37 PM
That is a nice theory ......
Here is the engineering reason... (fluid mechanics) 2 fluid pumps in a tight enclosed fluid housing (tank or reservoir) mounted on the same level, should both active at the same time or very close activating each separately i.e. front and then rear all in the same motion or incidence can create cavitation in the wiper fluid reservoir causing air to be pulled into the wiper fluid lines. So mounting them at different levels generally solves this effect from happening.
Lions7
Apr 19, 2023 04:18 AM
keenan
Mar 26, 2009 06:48 PM
rikardo76
Jan 23, 2009 02:01 PM
Wonger
Nov 22, 2007 06:37 PM
mazdadad
Aug 19, 2006 11:28 PM
