Turn Signals/Hazards stopped working
My 2003 Tribute's turn signals and hazards just quit working altogether. I have replaced the fuses, the bulbs, and the relay. Still no luck. I am at a loss. Any suggestions would be greatly appreciated!
Maybe the column stalk switch or the Hazard switch but you'd have to get out a meter and follow the 12V and GND paths through the switches and relay, unlikely to be in the wiring out to the bulbs or the bulbs themselves if all four corners affected,
Hi Everyone,
I just had the same problem (2006 Mazda Tribute, 2.3L L3? motor), the symptom was:
- Hazards not working
- All turn indicators not working (both left and right), no bulbs flashing at all.
Note: License plate lights, parkers, main lights, high beam, brake lights all ok
I checked the fuse box (it is located under the passenger side glovebox, down near the kickpanel). There are 2 x fuses for the indicators, see the car manual, there is a 10 amp (3 down on the right side stack- called "turn"), and a 15 amp ( 10 down on the right side - called "hazard"). Anyway the 15amp (hazard fuse) was blown, installed a new mini fuse and all fixed. Hope this helps the next person! Good luck!
three6mafia
Aug 14, 2012 09:05 PM
