sun roof drain cleanout
Old Aug 26, 2022 | 07:04 PM
Doug Lassiter's Avatar
Default sun roof drain cleanout
I typically try to clean out my sun roof drains with 0.095"string trimmer string, and compressed air. After doing that,in my old 2003 Tribute, water seemed to come through them, but maybe not as fast as it should have. Dealer established that they were "heavily clogged", and want to do a THOROUGH CLEANOUT in which they actually remove the lines to do a complete cleaning. $500!! Is this "best practice"?
Old Sep 11, 2022 | 12:08 PM
No wisdom here, I guess.
Old Sep 11, 2022 | 01:14 PM
LOL I just saw you post!!
GENERAL SERVICE RECOMENDATION:
The hoses or lines only need removing if damaged or clogged. If you keep up on routinely cleaning them, they should last for years. Routine means every season change of in tomes that you know that accumulation because of dirt and debris in the air may have been higher than normal for your area.
I use and recommend using a slightly diluted mixture of simple green and then a rinsing and finishing with low pressure air not to exceed 30psi (preset the volume on compressor or pressure valve).
This is one of those area's that tossing out the service schedule and instead should be considerably more than what is recommended.
Old Sep 12, 2022 | 07:26 AM
Thanks. Well, the line was clearly not completely clogged, but it was kind of dirty. I need to rig up a squirt bottle with a narrow tube that I can use to shove some cleaner down the line every once in a while.
Laidback
Feb 11, 2021 05:57 PM
Johnnie Meijer
Dec 31, 2019 01:43 AM
magnolia1028
Feb 6, 2019 08:06 AM
mpvowner
Mar 22, 2011 09:29 AM
murocflyer
Jan 27, 2010 06:36 PM
