Reprogramming my Fob
Old May 24, 2006 | 07:52 PM
tenytini's Avatar
Default Reprogramming my Fob
I own a 2002 Mazda Tribute LX and the battery in my fob died. I replaced it, but now it needs to be reprogrammed. I've tried the whole turning the key on and off, shutting and opening the door trick and it didn't work. I really don't have the money to take it to a dealer and have it reprogrammed. Any suggestions? Thanks a bunch!
Old May 25, 2006 | 07:48 PM
babyhuey's Avatar
Default RE: Reprogramming my Fob
Did not work because the programming procedure for the Tribby is way different then other Mazda's. Try this.
1: Start with key in 'off' postiion and all doors closed.
2: Now turn the key from 'off' position to 'run' position 8 times within 10 seconds ending with the key in 'run' (dash lights all on). If all went right the doors will lock and then unlock to indicate you are in program mode.
3: Within 7 seconds push any button on the first transmitter. Doors should lock and unlock to confirm programming.
4: Repeat step 3 with any remaining remotes within 7 seconds.
5: Turn key to off when done entering remotes and all should be back to normal.
Old May 25, 2006 | 08:31 PM
Joosed's Avatar
very good info babyhuey!
Old May 26, 2006 | 11:23 AM
tenytini's Avatar
Thanks a bunch babyhuey! I'll let you know how it turns out!
Old May 26, 2006 | 12:16 PM
Joosed's Avatar
Please let us all know how it turns out, ok?
Old May 26, 2006 | 02:12 PM
tenytini's Avatar
I must say that I was skeptical at first, but IT WORKED! I got it on the first try! Babyhuey, you're the best! Thanks!
Old May 26, 2006 | 06:51 PM
Joosed's Avatar
this is good to hear
Old Nov 4, 2007 | 05:33 PM
2002 Tribute's Avatar
Dido. Worked fine on my '02. Thanks a bunch.
mazdamike58
Mar 20, 2010 06:41 AM
birdsondabat
May 31, 2008 09:31 PM
Gavin
Oct 19, 2007 09:18 AM
Vettman 1
Nov 26, 2005 02:50 AM
Jmoore284
Nov 15, 2004 10:07 PM
