HELP! Front Tire blew Headlights out now
Old Jul 27, 2018 | 08:54 PM
Kpprod's Avatar
Exclamation HELP! Front Tire blew Headlights out now
My son was driving his 2004 Mazda tribute 6 cyl when the driver's front tire blew, ripping out the wheel cowling and dropping the wiring harness down that runs from the fuse ox under the hood to the dash and fuse box on drivers left kick panel. Replaced the tires but now the head lights are out. Only the turn signals and passenger front amber running light is working. There is a two conductor connector hanging down. This type of white and blue gasketed connector is normally used for wheel speed sensors but there is no sensor wheel speed sensor on this left front wheel. I have taken the fuse boxes loose and looked to see if there is a loose or frayed wire and nothing can be found. No frayed or broken wires in the wiring harness. I checked the fuse box under the hood for a blown fuse and I have found none. I believe that the fuses for the head lights are in the front part of this under the hood fuse box based on the nomenclature in the fuse box and the diagram I have found online. HELP!!! I do not know where to look next and my son needs his headlights working as he drives at night to and from work.
jterr
Feb 4, 2016 04:36 AM
Munchie
Jun 7, 2011 10:32 AM
highwayzoom
Mar 4, 2011 09:10 PM
brantminor
Mar 11, 2010 04:43 PM
pairof3s
Feb 26, 2006 04:38 AM
