P0191 - Car stalls whenever accelerated
I have a 2005 Mazda Tribute I, 2.3L, automatic, FWD, that has approximately 250,000 miles. The car stalls frequently whenever I try to accelerate at a medium-slow rate. I replaced a clogged fuel filter and replaced the fuel pump (separate problem), but it is still stalling. All spark plugs are functional. Does anyone know what the problem could be? How to fix it? How much it costs?
[QUOTE]p0191 Fuel Rail Pressure (FRP) sensor circuit performance/[QUOTE]
This is from the factory manual [QUOTE] 12 Fuel tank pressure sensor - The fuel tank pressure sensor, which is located above the fuel tank, near the fuel pump/fuel level sending unit module, measures the fuel tank pressure when the PCM tests the EVAP sys- tem, and it's also used to control fuel tank pressure by signaling the EVAP system to purge the tank when the pressure becomes excessive./QUOTE]
Hope this helps
Hope this helps
Mwhisler
05-29-2021 08:16 PM
mazdaB2300IDOL
04-30-2014 05:52 PM
djwho
03-08-2007 12:58 AM
djwho
12-14-2006 05:41 PM
