P0191 - Car stalls whenever accelerated
Old Oct 10, 2017 | 07:15 PM
Thomas Helmonds's Avatar
Question P0191 - Car stalls whenever accelerated
I have a 2005 Mazda Tribute I, 2.3L, automatic, FWD, that has approximately 250,000 miles. The car stalls frequently whenever I try to accelerate at a medium-slow rate. I replaced a clogged fuel filter and replaced the fuel pump (separate problem), but it is still stalling. All spark plugs are functional. Does anyone know what the problem could be? How to fix it? How much it costs?
Old Oct 11, 2017 | 04:53 AM
peedee's Avatar
[QUOTE]p0191 Fuel Rail Pressure (FRP) sensor circuit performance/[QUOTE]
This is from the factory manual [QUOTE] 12 Fuel tank pressure sensor - The fuel tank pressure sensor, which is located above the fuel tank, near the fuel pump/fuel level sending unit module, measures the fuel tank pressure when the PCM tests the EVAP sys- tem, and it's also used to control fuel tank pressure by signaling the EVAP system to purge the tank when the pressure becomes excessive./QUOTE]
Hope this helps
Old Oct 11, 2017 | 06:09 PM
simonsi's Avatar
Is your fuel cap tight with a good seal?
mazdaB2300IDOL
Apr 30, 2014 05:52 PM
gblvdgirl
Apr 15, 2007 09:55 PM
djwho
Mar 8, 2007 12:58 AM
djwho
Dec 14, 2006 05:41 PM
