EGR valve hose
Old May 22, 2017 | 12:59 PM
rcenturion's Avatar
Default EGR valve hose
I have a 2001 Tribute V-6
the small rubber vacuum hose connected to the top of the EGR valve is cracked, brittle, and dried out and is causing a p401 code (insufficient EGR flow)
the engine is running fine but I'd like to correct the problem
I thought it would be an easy fix just to replace the rubber hose, but the dealer only sells the hose as part of a set of connected hoses with connections to the entire EGR system. A photo of it is below. The hose I'm talking about is the one in the center of the picture with the elbow connection at the end.
Has anyone done a DIY fix for this hose?
Old May 23, 2017 | 06:42 PM
simonsi's Avatar
No but I'd think any automotive hose would do the trick, maybe fuel hose looks the right size?
Old Aug 26, 2018 | 09:04 PM
slantnose's Avatar
I just bought that hose from the Ford dealer $78. I found that if I order the parts from Mazda it takes longer and the parts arrive with Ford part numbers. Now I just order from Ford and get most of them in one day.
Old Aug 28, 2018 | 01:41 AM
peedee's Avatar
Just buy some vacuum hose of the right size a little longer than needed to allow for a wider bend in the hose will likely cost less than $10
lynn
Mar 14, 2006 11:01 PM
ignantmike
Jan 29, 2006 09:58 PM
vizz
Jan 11, 2006 08:54 PM
ash26
Aug 16, 2005 01:34 PM
bigboostin
Jul 29, 2005 09:45 PM
