Best replacement battery?
Old Aug 8, 2009 | 03:06 PM
marc515's Avatar
Default Best replacement battery?
Our 2002 Tribute basically does a lot of sitting in the driveway, and may sit for as long as 3 weeks or so without being used.
Last year we replaced the original battery with another Mazda battery, but still have a problem every now and then of a dead battery. I can understand it during the dead of winter, but last week it was dead!
So, just wondering what a better replacement battery would be, as I guess the Mazda standard does not all that powerful a reserve.
Thanks,.....marc
Old Aug 8, 2009 | 10:05 PM
Hi Marc,
First I would check to see if you have an excessive electrical draw. There should be a small load for radio memory, etc, but not much. Use a current/amp meter between one of the battery terminals and the batt cable, with a good charge in the battery. DO NOT try the starter this way.
If it turns out that you need another new batt, I would consider a deep cycle battery. Think marine battery.
Also, Optima batts are supposed to be good, but they are pricey.
Consumer Reports has consistantly rated Wal-Mart batteries among the best, and a best buy too.
DuraLast batts also rate well.
Old Aug 17, 2009 | 09:20 PM
johbowd77's Avatar
Default Batter Problem
Marc
I would look at the Battery connections , I had a similar problem in that it would go dead. Replaced the battery and still had a problem. After cutting and replacing the main battery connections all is good for 6 months.
another thing to check if your interior lights are going out when you lock the car. When I closed the small tail window sometimes the swith did not shut off the interior light.
Good luck
John B
Tribute 2002 v6 78K miles
speedy123
May 9, 2012 02:33 AM
sOngiepoO
Mar 9, 2011 05:45 PM
toscorpio
Feb 21, 2009 04:22 PM
kaplan1987
Feb 11, 2008 11:53 AM
