626 best used replacement AC compressor
Old Oct 8, 2008 | 02:19 AM
speedy123's Avatar
Default 626 best used replacement AC compressor
I've just been advised by the Air Conditioner mechanic that I need another AC compressor on my GD Mazda 626 2.2ltr 1991 auto sedan.
He said he regassed it but it won't pump at all - so its not worth pulling apart fixing. He recomends I find another good used second hand one
I don't want to get another 1991 compressor if I can help it, because at that age, a second hand one, might not be much better.
So does anyone know what the latest model Air conditioner is that will fit into my 1991 Mazda 626 2.2 ltr - if I get one second hand ??
AC Specs: 6K10-61-450A
506011-2070
"Diesel Kiki" ? brand made in Japan
Comp Type: DKS-13CH
Part Number: 506211-0870
Serial Number: 949A 288634
What are they worth second hand anyway in good working order?
Old May 8, 2012 | 05:28 AM
FatBobb's Avatar
Have you find new compressor? I have same problem!
Old May 8, 2012 | 08:13 AM
MazdaTirol's Avatar
Will the compressor even turn on? If you put 12V directly to the compressor does it run? Not to question your mechanic but it could be as simple as a bad pressure switch keeping the compressor from turning on, or a bad switch inside the car.
Old May 9, 2012 | 02:33 AM
FatBobb's Avatar
clutch is working ok. that was the first thing to check
dhundred
Oct 20, 2010 03:00 PM
Subbacultcha
May 19, 2009 09:17 PM
toscorpio
Feb 21, 2009 04:22 PM
depfer1
Jun 2, 2006 05:12 PM
