sohn adaptor
Old Aug 10, 2020 | 07:52 PM
TONKA456's Avatar
Default sohn adaptor
Hello All,
Is anyone using a sohn Adaptor on their rx8 does it work well are you happy with it.
Old Aug 11, 2020 | 09:19 AM
If you run mineral oil ( which is recommended & used by Mazda ) and you carry out regular oil changes, you shouldn't need to worry.
Old Aug 11, 2020 | 04:32 PM
TONKA456's Avatar
So you know the Sohn adaptor blocks off the omp and you feed fresh 2 stroke oils through it from a bottle mounted to the firewall
Old Aug 12, 2020 | 02:46 AM
I understand it. But why do you think its necessary?
Old Aug 12, 2020 | 04:52 PM
TONKA456's Avatar
I think it would be a good addition so you now burn 2 stroke clean oil all the time and you should also not build up carbon.
Old Aug 12, 2020 | 10:43 PM
Sounds like a good idea, so it uses the standard Mazda system?
I don't know the indepth workings on it, but I assume, from factory it uses engine oil feed from the engine oil pump, via a solenoid/valve? Does the sohn have its own pump to create pressure?
I'm kind of curious about its operating.
Old Aug 13, 2020 | 04:40 PM
TONKA456's Avatar
The Sohn is run off the omp with the same engine pump. It lives in front of the omp. look up sohn adaptor for rx8. Once it is installed you can run two stroke premix to burn instead of the 4 stroke oil from the oil pan.
trev0006
May 6, 2013 01:13 PM
Chris Ryan
Jun 19, 2012 04:19 PM
silverstwok
Aug 9, 2007 03:10 AM
rx heven
Jun 14, 2005 03:08 AM
WeaponX
Apr 14, 2004 09:33 AM
